Stylus for Writing on Forums?
Ironclad
I'm thinking of moving to this device, the LTE Note2. I moderate on a busy forum & I am wondering if I can use this devices great looking stylus powahz to scribe my replies directly into the forum. Or is it mainly for texting & notepad type things?
Is it compatible with tapatalk also.
Cheers.
The stylus is essentially your finger. Anything your finger does, it can do. When you handwrite it converts to standard text.
The keyboard has a stylus (or finger) entry mode which works whenever the keyboard ls present in any app and the stylus is out of its Slot
Works well even with bad handwriting
Roger
I've used handwriting with the stylus, but after several days I found out (in my case).that I was faster using my thumbs to Swype in any entry.
Sent using the force
