Stylus Recommendations for TF101
hollyrock
What stylus do you recommend for the TF101?
I have a sense of the handwritting apps that are available, but not really sure what stylus to use to handwrite notes on the TF101. Primarily it will be used for notetaking during meetings/classes.
Appreciate the feedback.
What handwriting apps are you using? I haven't found anything that is even remotely as good with what I had for my iPad.
I have yet to select the app. I figured that the stylus was key to having a successful app. I have been reading about all of the ones mentioned here but without a decent stylus it will be difficult to accurately assess them for my use.
