Root [T-Mobile] SU Zip won't copy to internal storage
jjr1968
Can anybody tell me how to get the SU Zip file to copy onto my HTC One internal storage so I can finish my ROOT ?:confused:
Sorry, bu, that's a pretty crappy video for a "Novice". He doesn't tell you exactly which thread to go onto and the entire video is so blurred I can't read anything to try and match it.
The video is in high def 1080p .. you know how to use youtube?
TWRP installs root
you don't have to copy anything
if you do wish to flash the zip,rather than use twrp to install,youll need to boot the phone and connect to the internal storage. i noticed when i rooted mine twrp no longer has a connect as usb storage option :mad:
