MisterGrumbles
What's the average temp supposed to be?
Mine averages about 90 deg. F.
I think what MP means by gotten hot, if you have picked it up at one time or another, and it was hot, as in, you think, "Wow, this thing is really warm!!!"
Go to Settings > Applications and go to processes. See what's going on might help.![]()
Update: I disable "data" service & battery came to normal. Again, enabled the "data" & experienced the same drain. So, at least, nothing wrong with battery or hardware; it must be some app consuming lot of "data".
Tried GSam & identified it as "multipdp"; but don't know what it is & how to kill it
if anyone can point out the way forward.......
There's a bit of a read about "multipdp" here at XDA in "..known battery drainers...":
http://forum.xda-developers.com/showthread.php?t=1308030&page=58
It appears that the remedies are different depending on how you use and configure your widgets/apps and screens, etc, as I look around.
We're sure seeing a lot of battery/resource issues being posted in forums all over for the S3; I dare say more than for any device that I've noticed, although new users of Androids in general do complain of battery drain right off, mostly those coming off phones with smaller, slower processors etc.
