I have been using Plane Finder to track a family member's flight this morning and my tablet has been working fine.
All of a sudden, Plane Finder was displaying "connection lost" but the plane on the screen was still moving. I couldn't really figure out why it was saying that as my internet wasn't down. Anyway after a few minutes the WiFi symbol disappeared from the top notification bar and my WiFi connection on the tablet was completely dead. I went into settings and it requested my WiFi password again so I typed it in, then it connected for a second or two, then it disconnected again. I've reset my router, I've closed all apps on my tablet, cleared the RAM, pressed 'forget' on the WiFi settings and set it all up again (three times). Turned the tablet on and off a few times and my tablet just won't connect to the internet full stop.
I'm really puzzled. My Galaxy S4 and my MacBook Air are working fine with my internet connection.
Can anyone suggest anything I can try next?
I might add that this tablet isn't rooted and hasn't got any modifications. It's just the standard out of the box interface running Android 4.3 and Samsung TouchWiz.
32GB WiFi only model.
Thanks in advance.
Thanks in advance.
