The_Superhoo
Havent had this problem until recently, and havent changed anything or started running a new widget, but my Maxx gets REALLY slow all the time now, and the memory is maxxed out, force restarting all kinds of apps. I look at the running apps list; it typically shows 700 or 800 used, but if I look at the list of apps running, I cant get anywhere NEAR that amount of memory.
I've tried clearing the cache, it didnt help. (dont know that it would, just always try that) I also try restarting the phone, which helps in the short term, but if I'm using it, it quickly becomes an issue again.
anyone else having this problem? Wondering if an app update or updates is causing the problem.
