Help Suddenly no signal!
NewSoul
Edit: It turns out my service provider disabled my SIM shortly after I activated it because my change of SIM was "unauthorized." They also reactivated my old SIM (which I was not able to tell without restarting my old phone). I have no idea why they allow you to change your SIM online if they just say that you are "unauthorized" to do so. WTF T-Mobile?
This phone is brand spanking new. As in, I put in the sim card and activated it online today. I sent out a text message and it worked, so I didn't think there would be any issues. My sim seemed to have been successfully activated. I left the phone charging for a few hours, came back, tried to send another text...but it didn't send and realized I had no signal.
I'm frustrated. I don't live out in the boonies. My other sim has been deactivated (different type), so I can't send or receive any phone calls or text messages.
Things I tried...
1. Toggling airplane mode
2. Restarting the phone (did this maybe 10 times already)
3. Manually selecting a network operator
4. Changing the APN settings (did this maybe 5 times, restarting in between)
I have T-Mobile, and my current settings are...
APN: epc.tmobile.om
APN type: default
Proxy: <not set>
Port: <not set>
Username: <not set>
Password: <not set>
Server: <not set>
MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
MMS proxy: <not set>
MMS port: <not set>
MMC: 310
MNC: 260
Authentication type: <not set>
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
Bearer: unspecified
Things I tried...
APN: epc.tmobile.om
APN type: default
Proxy: <not set>
Port: <not set>
Username: <not set>
Password: <not set>
Server: <not set>
MMS port: <not set>
MMC: 310
MNC: 260
APN protocol: IPv4
Bearer: unspecified
that sucks. Wish I could help you solve the problem, but can't. Running a phone through a Google Voice account helps in these case so that at least one can get their SSM and voicemails from the laptop.
