Suggest a Bluetooth dongle/ streamer??
medionpva
Member
Hi all,
I am looking for a bluetooth device that I can wirelessly connect my phone (S3 - JB) to, and that has a 3.5mm output so I can connect to my car stereo.
It needs to be able to stream music, use for phone calls, navigation etc. I have one at the moment, but won't allow me to hear calls via bluetooth, and I don't see the point plugging in a cable for calls.
Any suggestions?
Thanks"
So can you use it for voice calls as well? So the callers voice goes through the Bluetooth and you use the mic on the phone?
Thanks"
just to re-answer so others will see.
IIRC, the audio goes through the entire sound system. and the rare case i got a call while using the BT adapter, i did have to take speakerphone'ish style to the phone's mic at the bottom...
