super battery saver
by exiting I mean that battery saver is no longer active.
there is no error that I can see.
I have nokia G10
I found out that when battery hists below 50% that is not happening less. So it seems.
well personally if this is the app in question,Super Battery Saver, than i would consider not using this. android does a pretty good job at managing running services. what ends up happening is that as soon as a service gets closed, the phone will then need to re-run the service as you use the phone. in which the battery saver app will then in turn stop it. this process could keep going on and on and thus making the battery life even worse. or if anything this app will constantly be scanning your phone and basically be running all the time which also can contribute to bad battery life.
these kinds of apps used to be called task killers.
i never have used any of these kinds of apps on any of my phones.
if you are having battery life issues, try these tips:
https://motorola-global-en-uk.custh.../~/tips-to-extend-the-battery-life---moto-g10
especially tips on keeping adaptive battery and battery optimization on.
no, "super battery saver" that I use, is already in the settings -> Battery -> super battery saver
It seems it comes with android os
Thank you for the link, it is very useful
