You know this because you tested it, or just read the specs? Because I have loaded the three latest versions and BT does not work on my phone. It may be a hardware issue also, I just don't know and have not been able to locate the thread with instructions to fix this.
The buttons to sync are grayed out and when I press the connect button it does not respond.
-Recompiled Launcher and Nexus Launcher
--Live Folder FC fixed
--Portrait/Columns options fixed
-Updated Working Renice Script
-Remove Launcher Script, based on the One you want to use you can remove the other for improved battery life.
-Updated Italian Locales
-Display Battery Percentage option in Spare Parts
-Other Stuff I Always forget
