superpad 2 flytouch 3 ( External Keyboard)
burguk
Hi, Just got a Flytouch 3 + wallet with built in keyboard. however cannot seem to get the external keybord to work .. seems to work when i plugged into the USB on my pc..
Anyone has any ideas or am i am missing something simple ! :)
TESTED ON:
Superpad II, 2.3 Android OS (Rooted w/GingerBreak)
Semi Fix 1 (Best):
Installed BusyBox Pro & Usb Host Controller
Keyboard works when I plug it in before turning on system. When pad is turned off or restarted, function of keyboard stops.
Semi Fix 2 (Hotplug):
Plug keyboard/case into computer and type, then unplug & plug directly into the top Superpad usb connector. When pad is turned off or restarted, function of keyboard stops.
*UNPLUGGING KEYBOARD WILL DISABLE BOTH METHODS, HOWEVER..
Re-Enable After Unplugging:
While unpluged, single press power to black out screen (not turn off). Plug in USB Keyboard, turn on screen/unlock. After doing this once, you can unplug/plug back in all you want w/o the need to black out screen (On my pad at least)
*Still working on a "plug and play" type solution.
