Welcome to Android Forums, kane.
When you say link, do you mean connect? You should be able to simply plug it in using the USB cable and connect as mass storage (you may need to pull down the notification bar and tap the USB connected notice.) If you mean sync, then the link El Presidente gave is the place to go.
