Help SuperPad 3 stuck on screen
aubreaa
I factory reset my SuperPad today and after that every time I try to go and boot up, my screen gets stuck on the green welcome screen.
I have tried everything that I can think of in order to get it where it is not stuck, and yet nothing will work.
I tried the reset button, I tried to reboot, I tried to factory reset again, and no luck!
Please help me ):
Please help me ):
Did you botr down the details of your tablet ? its version and other details.
Without the details we cannot help .Atleast let us know the date of purchase and the charger you are haaving ie the voltage
I bought it about a month ago, I don't really know how to know these things, the instructions are in Japanese so I can't tell.
And now it is turning on and off by itself.
At least give the structure of the ttablet ie how many card slot are there and how many volts charger ? If you purchased online gice the link from where you purchased so that we can come to some conclusion and take chance to repair it
Mean while try this things
1. Press vol + button and press the power button if nothing happens repeat with vol - mutton
2 press home button + back button and power on the unit.
post the result
After you give the details of your tab will will try for other method
i have the same problem SuperPad 3/ Flytouch 3 stuck on screen
I factory reset my ft3 today and after that every time I try to go and boot up, my screen gets stuck on the green Android logo screen. Did not pass that screen to the linux penguin
I tried the reset button, I tried to reboot, I tried to factory reset again, I tried firmware tim6a and no luck!
Please help me ): the system info:
My Flyoutch 3 stats:
Version: Unknown [Sorry, I don’t know how to check it.]
Model No: Disco10
Android version: 2.2-20110803
Kernel version: 2.6.32.9 zjd@dtlinuxserver #34
Build No: FRF85B
Voltage is 5v not 9v
its new Nov 2011
i have a super pad 3 its not rooted or anything, all stock everything. I HAVNT EVEN TRIED TO DO ANYTHING TO IT AT ALL.. the battery died lastnight and screen has been black since... sombody pleaseeeeee help!! i've tried every button combo ever invented and the charging light comes on and even went from red to green (showing its fully charged) PLEASE HELP!
