Help superpad Flytouch 3 problem
meeshy
Hi. Everytime I start using it, a pop up box appears saying: "Sorry!The process android.process.acore has stopped unexpectedly. Please try again." If i then press the Force Close button, it disappears, but then re-appears a few moments later. Can anyone help? It's driving me up the wall!
Have you tried clearing the application cache?
Sorry to sound stupid, but how do i do that?? Thanks
I guess that really depends on which application is causing the crash....
Try menu/settings/applications/manage applications/all/google services framework/clear data
that will reset all the google stuff.. you will have to log in the google again...
I suppose it could be calendar sync or contacts sync..same procedure.. you will lose any contacts & calendar entries you have stored on the tablet
Anybody else??
No joy with that. Cleared it all as you suggest, but it keeps popping up! I can't even seem to be able to do a Factory Re-set as the instructions in my manual don't correspnd with the tabs that appear on the screen!!
I don't understand this bit.... the factory reset (I believe) involves holding the +volume, the 'back' button and the power on button together, you don't get as far as having tabs on the screen.........I really don't want to test it as I don't want to reset my tablet!
There is a uImage and a uImage_Recovery file on the internal tf card... I assume the 'reset' procedure re-writes the uImage file with the uImage_recovery file.
