SuperSU is the better solution in my opinion.
I am having problems with Superuser - it keeps denying root access and it wont update the binaries. I seen SuperSU but it wont update either. I guess you cant have two applications for root? I would like to try it but it wont update binaries either. Something not right...SuperSU is the better solution in my opinion.
does it work on gingerbread as well?
)I am having problems with Superuser - it keeps denying root access and it wont update the binaries. I seen SuperSU but it wont update either. I guess you cant have two applications for root? I would like to try it but it wont update binaries either. Something not right...
