ZeRoseDev
First here are some helpful IMPORTANT tips:
1. You need to be Rooted. Guide HERE.
2. You need to have CWM. Guide HERE.
3. You should make a backup of your current ROM. Guide HERE.
4. You MUST backup your 3G(If you've already flashed a ICS or JB ROM, this wont backup your 3G). VERY IMPORTANT.. Guide HERE.
DOWNLOADS
Supreme_V2_Complete_Edition.zip:HERE
ICS baseband.zip: HERE
-- HERE is the Gingerbread Baseband; if you would like to go back to Gingerbread ROMs, you must first flash this baseband using the same steps
First here are some helpful tips:
-Guide located HERE
-Guide located HERE
-Guide located HERE
4. You MUST backup your 3G.
-Guide located HERE
1. Place all required files on your SD Card.
-"ROM".zip, Gapps.zip, and baseband.zip (if it's required).
--Do not extract the "ROM".zip place the zip file on your phone. (Some .zip files contain the ROM and the Gapps, you will need to extract these to recover the "ROM".zip and the Gapps.zip, open the .zip to make sure you see folders inside (data, system, boot, META, etc), not more .zip files)
2. Reboot your phone into "Recovery Mode".
-Power down the device, then hold Power and Volume Up until you reach the Recovery Menu; once there, use the Volume buttons to navigate, and the power button to select.
3. Select "mounts and storage". -Select yes.
4. Select "format /cache". -Select yes.
5. Select "format /data". -Select yes.
6. Select "format /system". -Select yes.
7. Select "format /datadata". -Select yes.
***WARNING; DO NOT FORMAT /SD Card***
8. Select "format /cust". -Select yes.
9. Select "+++++Go Back+++++".
10. Select "wipe cache partition". -Select yes.
11. Select "advanced".
12. Select "wipe dalvik cache". -Select yes.
13. Select "+++++Go Back+++++".
14. Select "wipe data/factory reset". -Select yes.
***If you are on the wrong baseband continue;
if you're on the correct baseband skip to step 17***
15. Select "install zip from sdcard".
16. Select "choose zip from sdcard".
---Navigate to the Baseband.zip and press power to select it.
17. Select "install zip from sdcard".
18. Select "choose zip from sdcard".
---Navigate to the "ROM".zip and press power to select it.
**If you need to install Gapps**
19. Select "install zip from sdcard".
20. Select "choose zip from sdcard".
---Navigate to the Gapps.zip and press power to select it.
21. Select "+++++Go Back+++++".
22. Select "reboot system now".
This can take anywhere from 2 - 10 minutes, please be patient.
Once the phone boots, it is recommended you wait about 5 minutes to let everything load properly.
Did I help so much that you want to buy me a coffee?
Do that HERE.
How to Install Supreme Emotion UI v2 ICS
DOWNLOADS
-Guide located HERE
-Guide located HERE
-Guide located HERE
-Guide located HERE
Do that HERE.
