Root swapping ext sd with internal sd card ?
Thanks a lot , your real quick . I was kind if hoping for something else though , not that im not great full , dont get me wrong . Just that i seen on the motions they have a boot buddy script to swap them . You think someone can do this on ours ?
Hmmm I really don't know much on this subject. I've never needed more space than what comes on the phone.
All I really know is that this was a decision by google to remove the feature. It was causing more problems than it was helping. Many apps are dependant on background services so when the sd is unmounted it would cause bugs and apps to crash. I cant say that we'll ever get a hack for this. Not sure
I am looking for this also, perhaps some one creating custom roms they can build something in to make internal a partion. I would really like to see this done, I got to many games. I never had a problem with sd mounting, it always did.
If you want to use the boot buddy script from the motion... just install it on here. Almost everything from the Motion works on this phone, only real issues I see are themes since our screen is a different quality / size.
