groggy....
you seem to be having problemos with that Blade/OSF....
You had probs with Gen 1 ROM and, now, after TPT, with SS Gen 2 ROM....
I don't think the trouble is with the ROM's at this point.....
perhaps hardware or some particular s/w you are using!!!
You bought this phone from eBay or somewhere??
I would contact the seller....
if it still crashing randomly, for no apparent reason, and you are not using some dodgy s/w, or are not overclocked to too high frequency, I would recommend running at default 600MHz for a time....
Also, you could try a different SD card.....
you need to try eliminating stuff before asking questions with no real info given......
You may be asked to provide logs....
Catlog from Market will do this for you...
Modaco is the best place for ZTE stuff....
but you need to give all info, or ppl will not help!!!!
http://android.modaco.com/index.php...edish-Snow-RLS4b-(Android-2.3.5)#entry1886182
