Help SwiftKey not working
All of a sudden, my SwiftKey keyboard stopped working. This happened right after I installed a few applications(apps2SD,ADW.launcher, and FX Camera)
The regular sense keyboard works fine, but on any application on the phone, the SwiftKey keyboard won't open. I can tap the text entry box, but the keyboard won't pop up. Any suggestions? It hasn't been moved from my phone memory
Not sure if it's going to help but this is how I would troubleshoot it..
1) Try rebooting the phone (if that doesn't work, then go on to 2)
2) Go to a screen where you need to type and press and hold in the text box and make sure the "input text" method is set to SwiftKey (if that doesn't work, go to 3)
3) Make sure in settings>language and keyboards, that it's still checked.
If none of that works, I would probably uninstall and install again.
Hope it works out :)
