natarajan1986
My layout xml
I am having webview inside linear layout which in turn inside two relative layouts and the code to detect swipe is
My problem is when i swipe left to right or right to left
onfling method it is not getting called.I have pulled my hair for whole day so can any one help in this issue.
Code:
<?xml version="1.0" encoding="utf-8"?>
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:orientation="vertical" android:layout_width="fill_parent"
android:layout_height="fill_parent" android:background="#ffffff">
<RelativeLayout android:id="@+id/l1"
android:orientation="horizontal" android:layout_width="fill_parent"
android:background="@drawable/blank_header"
android:layout_height="60dip">
<Button android:id="@+id/home" android:layout_height="wrap_content"
android:layout_gravity="left|center_vertical|center_horizontal"
android:layout_width="wrap_content" android:layout_marginLeft="3dip"
android:minHeight="20dip" android:layout_marginTop="0dip"
android:minWidth="30dip" android:background="@drawable/btn_back">
</Button>
<LinearLayout android:layout_height="wrap_content"
android:gravity="center" android:layout_width="fill_parent"
android:layout_centerVertical="true" android:layout_marginRight="80dip"
android:weightSum="1">
<TextView android:layout_marginTop="5dip"
android:layout_marginLeft="215dip" android:text="Epub Reader"
android:marqueeRepeatLimit="marquee_forever" android:textSize="15dip"
android:layout_gravity="left" android:layout_width="fill_parent"
android:id="@+id/txt_chaptertitle" android:ellipsize="marquee"
android:singleLine="false" android:layout_height="wrap_content"
android:typeface="serif" android:textStyle="bold"
android:layout_weight="0.18"></TextView>
</LinearLayout>
</RelativeLayout>
<LinearLayout android:id="@+id/l2" android:layout_below="@id/l1"
android:gravity="right" android:background="#ffffff"
android:layout_height="wrap_content">
<TextView android:textSize="15dip" android:id="@+id/txt_pageCount"
android:layout_height="30dip" android:layout_width="70dip"
android:layout_gravity="bottom|right|center_horizontal"
android:paddingTop="5dip"></TextView>
</LinearLayout>
<LinearLayout
android:layout_below="@id/l2"
android:layout_above="@id/l3" android:orientation="vertical" android:layout_width="fill_parent"
<WebView android:id="@+id/webView3" android:layout_height="fill_parent"
android:layout_width="fill_parent">
</WebView>
</LinearLayout>
<RelativeLayout android:layout_height="70dip" android:gravity="center" android:layout_width="fill_parent" android:id="@+id/l3" android:background="@drawable/footer" android:layout_alignParentBottom="true" android:layout_alignParentLeft="true">
<Button android:layout_height="wrap_content" android:background="@drawable/btnnext" android:id="@+id/button4" android:layout_width="wrap_content" android:layout_centerVertical="true" android:layout_alignParentRight="true"></Button >
<Button android:layout_height="wrap_content" android:background="@drawable/btnprevious" android:id="@+id/button3" android:layout_width="wrap_content" android:layout_centerVertical="true" android:layout_alignParentLeft="true"></Button >
</RelativeLayout>
</RelativeLayout>
Code:
public class Reader{
public void onCreate(Bundle savedInstanceState) {
gestureDetector=new GestureDetector(new MyGestureDetector());
class MyGestureDetector extends SimpleOnGestureListener implements OnGestureListener{
@Override
public boolean onFling(MotionEvent e1, MotionEvent e2, float velocityX, float velocityY) {
try {
if (Math.abs(e1.getY() - e2.getY()) > SWIPE_MAX_OFF_PATH)
return false;
// right to left swipe
if(e1.getX() - e2.getX() > SWIPE_MIN_DISTANCE && Math.abs(velocityX) > SWIPE_THRESHOLD_VELOCITY) { // left swipe
if(isLandscape()){
if(isnextButton){
forward();
else{
if(isnextButtonPot){
forwardPotrait();
else if (e2.getX() - e1.getX() > SWIPE_MIN_DISTANCE && Math.abs(velocityX) > SWIPE_THRESHOLD_VELOCITY) { // right swipe
if(isLandscape()){
if(ispreviousButton){
previous();
else{
if(ispreviousButtonPot){
previousPotrait();
catch (Exception e) {
// nothing
return false;
