Apps Switch off connection
Does anyone know of a keyboard shortcut to switch off the signal/connection while you have the emulator running in Eclipse?
I need to test that a certain part of the app will function if the device loses signal while the app is running. I believe you can switch the connection off prior to starting the app but I need a connection to start the app and then need it to drop after that.
