I tested this out and I decided I may not use it. Before you change the UE State for the first time, check check out what your CURRENT CONNECT STATE is. If you haven't changed your UE State since your last reboot before you access this the state will be "RAT is DUAL".
DUAL as is Dual mode (3G or GSM, whichever works in the area you are in). When you change RAT to GSM it limits your phone to GSM. That's what you want it to do. But, when you change RAT to WCDMA, it doesn't go back to Dual mode, it switches to 3G only. So if you lose your 3G connection you won't be able to connect to available GSM signals in the area unless you reboot your phone.
