Root Switching ROMS and Partitions
MikeC1408
When switching ROMs is there anything you need to do re the partition on your SD Card?
Will it stay, do you need to repartition?
Switching ROMs won't change SD card partitions.
When you first install a ROM with A2SD+ you should do the partitioning before installing the ROM. But you only need to do it the once.
Wiping the phone to change ROMs will delete the contents of the ext partition (same as it wipes the internal memory), but the partition will remain and when you restore/reinstall your apps they will go back to the partition.
