Help Swype for Devour
Do you have the "unknown sources" box checked under applications? Also what file explorer are you using to install this?
Unknown sources is checked. I've used OI explorer, appsinstaller, and astro. I always get the same message when I try to install Swype now. I think I might need to do a factory reset on her phone.
-edit- Factory reset took care of the problem.
