Swype not working after Firware upgrade (fix)
Clevo89
Hello, just wanted to post about how I fixed the Swype Keyboard after upgrading the firmware on my IDEOS X5. In my case it was pre-installed when I bought the Smartphone.
After the firware upgrade when ever I tried to use swype it would scroll up, stutter then immediatly scroll back down. Totally unusable.
To fix:
Got to:
Settings/Applications/Manage Aplications then:
All tab/scroll down to Swype and press
then Clear data
and that's it.
It'll take you back to when you first used it with a pop up screen wanting to teach you how to use it.
I hope the above information helps you too and saves you time in looking through Google.
Regards
Clevo
To fix:
Got to:
then Clear data
and that's it.
Regards
Clevo
Uh, thanks dude, it was staying to piss me off
Hi Clevo, what Firmware update caused the problem?
Was this the Huawei online update?
Thanks. Neil.
