Sync EVO and Aria
Ok i bought the HTC EVO and now im looking at the Aria IF I sync the Evo then come and sync the aria will it sync.be the same(the info, ringtones. and screen?) or is that even possible?
Oh and i did do search.
The only thing that would sync would be contacts and calander, and those changes that you made while having the first device...ringtones? Apps? I dont think so...that stuff isnt uploaded to your google account...
or maybe im just not understanding you...
this is my first day with the Aria..coming from another android device, tho...the very WEAK Backflip..
I believe there are tools on the market to do this though I believe they do it with a backup and not a sync. So any time you make a change on one phone it won't reflect on the other. All syncing has to be done manually via backups. Unfortunately I don't know the name of any of the tools off the top of my head. I'll see if I can search and find it though.
