Help sync galaxy s with itunes using MAC
jackie101
Hi,
I am trying to sync my galaxy s with itunes. I followed the steps on the llink below but it does not explain how to do it on a MAC. It says I should download ituneswalkman first and then it does not explain how to do it. Is there anything better than this? I've read a few posts around here but nothing specific to MAC. I have an SD card in and I did select mount but after that, no idea what to do. Any help will be appreciated.
tnx
How to sync the Samsung Galaxy S with iTunes - Know Your Cell
Hi,
I have a desire HD and a mac - boyf has a SGS which is why I'm on here.
Anyway the best way to sync stuff with mac/android is to use double twist - you download for mac (it looks exactly like itunes) and also you can (but don't have to) download doubletwist music player for your phone (I did as the stick HTC one is rubbish). You can also buy the wifi syncing version so you don't even have to plug your phone in (this does eat battery though so I don't use it)
Anyway if you install doubletwist on your mac then plug in your android it will tell you exactly what to do :-)
