If you want to sync data wirelessly between your Amdroid phone and Windows PC, I think a great app for that is SyncBox. It can transfer files and folders directly from the phone to PC or
vice-versa using WiFi. So this is fast (faster than Dropbox because of WiFi), and safer. For
example: if you sync your Pictures folder on your phone to the PC's Pictures folder, and set the
sync direction to Phone to PC, and you take a picture on your phone, that picture will
automatically be copied to the PC.
There are tow versions of SyncBox (or Wifi Dropbox):
Lite (free): supports only 1 folders and its subfolders to sync, ad enabled, and slower
https://market.android.com/details?id=com.rainy.syncboxlite
Pro ($2.99): supports unlimited folders, fast, ad free, a lot of options can be set.
In order to make the app run, you have to download the client app (for your Android Phone), and a server app for your PC.
If you have any questions, plese feel free to ask: szantogab@gmail.com
