DaggaDraad
Upgraded to ICS. Any ideas, please, for sync'ing my contacts to Outlook 2010. Using a calendar app called Gemini? Anyone using Gemini and sync'ing to their Outlook 2010?
Thanks
Thanks
My Outlook is syncing to Google, so I just sync my phone to Google and voila everything syncs back to Outlook.
As for playlists, it depends on what music player you use on your computer. If you have iTunes on it and prefer to use that, You need to use DoubleTwist or iSyncr on your phone to have it sync. Otherwise, WinAmp and Windows Media Player syncs with the phone as well.
Chanchan05 hi
Thanks for your reply. I heard about doing a double sync and was not too happy about it. Can you explain the process to me, please?
Thanks
