I use a folder named Music, because thats what doubletwist created when i synced it the first time. I never bothered to change it. Not to mention i don't actually have ANY mp3 files, they are m4a.
Thanks for all the replies. Is double twist and itunes sync free?
double twist is not free on the market
I stand corrected. I thought I saw it as free, but it is .99. My bad...
iTunesSync, however, is free.
Doubletwist is an app for the phone, and iTunesSync is a Windows program.
it's a shame it isn't free, sounds like a useful app but I'll just stick to taking the sd card out of my phone and putting it into the computer and dragging the songs over to it.
Can't you leave it in the phone and when you hook it up to the computer mount it as a drive? That would save from taking it out of the phone.
That was gonna be my next question, I have hooked the Inc to the computer via the usb cable but it just never showed up on mycomputer as a drive. It installed and everything too which is weird. Sorry for jackin' the thread. Any suggestions?
Mine does by design. When I hook up the USB cable, a screen pops up and asks what I want to do (just charge, use as a disk drive, etc).
Got to Settings->Connect to PC and there are 4 choices. Have the 'Ask Me' checked and that should come up. If the third choice states 'Mount SD Card, your card isn't mounted for whatever reason.
When you plug the phone in, it will ask you what you want to do, and choose Disk drive, and then hit 'Done' at the bottom, and your PC should show it as a removeable drive.
I am in the same boat as you... I tried to to mount the phone as a drive but I couldn't figure out how to drag and drop songs onto the card...this is my first smartphone as you can probably tell
Thanks, i'll give it a try in a few. letting it fully charge for a few more mins.
