Bethany McDonald
Where can I get a list of stock system
apps?
apps?
the entire system apps? that list could be quite long. system apps are basically your entire os. it is how android is compiled. for the most part, there should no reason why you need to look at system apps. and also you have to be careful looking into system apps as they sometimes have very sinister sounding names, but are very harmless.Where can I get a list of stock system
apps?
I had a Spyware called Update System Service, and now I have 2 or 3 system apps named the same thing, and new files. I'm just wondering if the Spyware installed additional apps, or files...etc...
update system service is a system app which has to do with updates. so the thing is that spyware can't be a system app. in order for that to happen, the spyware would need would need permission to read and write onto your system partition.......in other words your phone would need to be rooted. and rooting is not as easy as it used to be. rooting these days requires adb programming setup on a computer and your phone hooked up to it. so unless you handed a phone to someone who then attached to a computer, i doubt your phone is rooted.I had a Spyware called Update System Service, and now I have 2 or 3 system apps named the same thing, and new files. I'm just wondering if the Spyware installed additional apps, or files...etc...
My husband put it on my phone and admitted to it. It was creating folders in my phone which contained the info the Spyware was collecting. That's actually how I found out about it...https://www.google.com/amp/s/techcrunch.com/2020/02/20/kidsguard-remove-stalkerware/amp/update system service is a system app which has to do with updates. so the thing is that spyware can't be a system app. in order for that to happen, the spyware would need would need permission to read and write onto your system partition.......in other words your phone would need to be rooted. and rooting is not as easy as it used to be. rooting these days requires adb programming setup on a computer and your phone hooked up to it. so unless you handed a phone to someone who then attached to a computer, i doubt your phone is rooted.
i agree with @puppykickr , what makes you think you have spyware on your phone?
just factory reset the phone......done no more spyware.My husband put it on my phone and admitted to it. It was creating folders in my phone which contained the info the Spyware was collecting. That's actually how I found out about it...https://www.google.com/amp/s/techcrunch.com/2020/02/20/kidsguard-remove-stalkerware/amp/
Perfect.just factory reset the phone......done no more spyware.
