HeadScratcher
I have a FireTV Gen 2 box. Many YouTubers are saying this can be done on the stick or box.
For me, it either says “connection failed” or gets stuck on the “Connecting to (IP address here) Please Make sure the target device has network ADB enabled. You may need to except a prompt on the target device if you are connecting to it for the first time from this device.”
No option to accept pops up.
I have enabled “ ADB debugging“, “ Apps from unknown sources“, and “USB debugging”.
I’m using the IP address from the about menu.
