Help system data problem
I've owned the android K7 for about two months now and the internal memory storage is around 8gb. I also have a 32gb SD card and any apps that i can move to it are on it. The problem is that under misc. Data there's a slot labeled system data and it takes up 3.62gb currently of the internal storage... It's taking nearly half of the internal data and I'm obviously running into storage problems help ASAP would be nice.
System data is the operating system (the Android OS), and can't be moved or deleted. Because if you did, you would have a nice shiny paperweight, and NOT a smart-phone. It's just like Windows, Linux or macOS occupies a certain amount of space on your computer's hard-drive or SSD. Delete that, and your computer wouldn't boot.
Quite frankly only 8GB internal storage can be pitifully inadequate these days in a modern smart-phone, especially if using things like Facebook.
I would take your word on that but it's been going up fast. I also rooted my phone today to see what's going on and there's this data called APK and it has the same data sizes as apps i have installed, like app data duplicates
What is the size of your "/data" partition, and how much of that is free? If you can't easily see that (and the system storage app is notorious for describing things in a confusing way, as you've found) try installing a little app called Storage Truth and seeing what it says.
The /data partition is the part of the phone's internal storage that's accessible to you, so the size of that partition is the maximum space you could ever have immediately after a factory reset and wipe of the "internal SD card" (which is really a part of the internal storage pretending to be an SD card). It will be a lot less than 8GB. The other partitions contain the ROM, kernel, system cache partition, and lower-level firmware, and their sizes are fixed. Most likely a large part of what the device is calling "system data" is those partitions (not just the space used within them, but the entire partitions, since they are inaccessible to the user).
What else the phone calls "system data" will depend on what LG have decided to bundle under that label. It might be updates to system apps: because the ROM is only modified by system updates, updates to individual system apps via the Play Store are stored in the /data partition the same as your own downloaded apps. It might be including data stored by those apps as well, or it might not. If what it is calling "system data" is growing then there will be something like that there (or maybe system log files, but I've never known those to become large myself). To some extent it doesn't matter: you can uninstall updates to system apps if you want or clear their data, so what heading the LG storage menu puts these data under doesn't make any difference, apart possibly from confusing the user.
Is the phone rooted
