Root System dump
I would appreciate this ;)
may I ask which method you used to obtain the system directory and/or img?
:/ but how you use adb pull on stock system? don't you need unsecured boot.img to do so?
assuming youre rooted : adb pull /system
to get boot.img
go to terminal and :
[HIGH]adb shell
su
dd if=/dev/block/mmcblk0p3 of=/sdcard/boot.img [/HIGH]
im not exactly sure what the dev block is for firmware, so mmcblk0p3 is a guess. i used a tool from the app store called Diskinfo to find it out
to get boot.img
[HIGH]adb shell
su
haha nahh im jus an idiot!! I always seem to forget you can do a pull without insecured boot.img you just cant push items/files lol derrrrrr
ok thanks man haha
I was trying to do
adb remount (just out of habbit)
and it says unable to find device, drivers are installed and im rooted lol I just never actually tried to go through with the pull haha wow im dumb..
thanks boneface ;)
this may help some of you
~ $ adb shell
shell@android:/ $ su
shell@android:/ # ls -l /dev/block/platform/msm_sdcc.1/by-name
lrwxrwxrwx root root 1970-01-01 05:33 aboot -> /dev/block/mmcblk0p9
lrwxrwxrwx root root 1970-01-01 05:33 boot -> /dev/block/mmcblk0p11
lrwxrwxrwx root root 1970-01-01 05:33 cache -> /dev/block/mmcblk0p16
lrwxrwxrwx root root 1970-01-01 05:33 cust -> /dev/block/mmcblk0p21
lrwxrwxrwx root root 1970-01-01 05:33 fsg -> /dev/block/mmcblk0p23
lrwxrwxrwx root root 1970-01-01 05:33 misc -> /dev/block/mmcblk0p18
lrwxrwxrwx root root 1970-01-01 05:33 modem -> /dev/block/mmcblk0p3
lrwxrwxrwx root root 1970-01-01 05:33 modemst1 -> /dev/block/mmcblk0p12
lrwxrwxrwx root root 1970-01-01 05:33 modemst2 -> /dev/block/mmcblk0p13
lrwxrwxrwx root root 1970-01-01 05:33 nvm -> /dev/block/mmcblk0p2
lrwxrwxrwx root root 1970-01-01 05:33 oeminfo -> /dev/block/mmcblk0p1
lrwxrwxrwx root root 1970-01-01 05:33 pad -> /dev/block/mmcblk0p10
lrwxrwxrwx root root 1970-01-01 05:33 persist -> /dev/block/mmcblk0p15
lrwxrwxrwx root root 1970-01-01 05:33 recovery -> /dev/block/mmcblk0p19
lrwxrwxrwx root root 1970-01-01 05:33 recovery2 -> /dev/block/mmcblk0p20
lrwxrwxrwx root root 1970-01-01 05:33 rpm -> /dev/block/mmcblk0p7
lrwxrwxrwx root root 1970-01-01 05:33 sbl1 -> /dev/block/mmcblk0p4
lrwxrwxrwx root root 1970-01-01 05:33 sbl2 -> /dev/block/mmcblk0p5
lrwxrwxrwx root root 1970-01-01 05:33 sbl3 -> /dev/block/mmcblk0p6
lrwxrwxrwx root root 1970-01-01 05:33 splash -> /dev/block/mmcblk0p22
lrwxrwxrwx root root 1970-01-01 05:33 ssd -> /dev/block/mmcblk0p24
lrwxrwxrwx root root 1970-01-01 05:33 system -> /dev/block/mmcblk0p14
lrwxrwxrwx root root 1970-01-01 05:33 tombstones -> /dev/block/mmcblk0p17
lrwxrwxrwx root root 1970-01-01 05:33 tz -> /dev/block/mmcblk0p8
lrwxrwxrwx root root 1970-01-01 05:33 userdata -> /dev/block/mmcblk0p25
shell@android:/ # dd if=/dev/block/mmcblk0p11 of=/sdcard/boot.img
16384+0 records in
16384+0 records out
8388608 bytes transferred in 5.132 secs (1634568 bytes/sec)
from recovery img
/boot emmc /dev/block/platform/msm_sdcc.1/by-name/boot
/cache ext4 /dev/block/platform/msm_sdcc.1/by-name/cache
/data ext4 /dev/block/platform/msm_sdcc.1/by-name/userdata length=-16384
/misc emmc /dev/block/platform/msm_sdcc.1/by-name/misc
/recovery emmc /dev/block/platform/msm_sdcc.1/by-name/recovery
/external_sd vfat /dev/block/mmcblk1p1 /dev/block/mmcblk1
/system ext4 /dev/block/platform/msm_sdcc.1/by-name/system
/cust ext4 /dev/block/platform/msm_sdcc.1/by-name/cust
/sdcard datamedia /dev/null
