System memory
  • Thread starter Thread starter jad_eliz
  • Start date Start date
J
jad_eliz
Guest
System memory is 158 mb of which 20 mb is free. There are no movable applications. How can I see what is occupying my system memory and remove them
Hi
There is a small app called diskusage which gives a graphic view of use of space which i find really useful for seeing what is using up memory. You may need to remove a few apps and clear the caches of all of them. Another app called history eraser helps with this
Roger
