Help System process(dboxed_process0) drain my phone battery qucikly
  • Thread starter Thread starter Axel Yeung
  • Start date Start date
A
Axel Yeung
Guest
Hi. My phone is Samung Galaxy S4 with Android 4.4 KitKat. Sometime, the battery drain very quick. Almost 1% per minute. I have installed GSam for checking. It show it is System process named "dboxed_process0" use up the most battery.
I have searched this for a while. Some site said it is named "sandboxed_process" from Google Chrome. OK. I disable the Ghrome but the problem still occur.
Does anyone know this "dboxed_process0" shit is?
The phone was only off charge for 9 minutes when you took that shot, so any process which was active at the time could dominate usage. Is it the same when it's been running for a while?
As for what it is, I can't find it on my phone, but I also don't have Chrome installed at all. The name reminds me of Dropbox, but I can't find any indication that it's actually connected to that app (which I do have installed, and started up to be sure but still see no dboxed_process0).
Yes.It is the same when it's been running for a hour. It said it uses up 10% of battery.
Well. I have to say. It is not always happen.
But sometime it is even worse. It can use up 20% in a hour.
You were playing a game? Try to charge your phone to full, and not use it at all for one hour. See what uses the most battery then. Games access several background processes.
