ROMs System ROM Upgrade Help
AgentCPU0
Member
My tablet is currently running 4.4, and I did some research regarding a possible upgrade. I ended up finding out my hardware specs meet the requirements to upgrade to 5.1. But I can't figure out where I need to go to actually download the ROM, or even how to install it, for that matter. Does anyone happen to know where I can find either of them?
If you go to System Update if no update shown up mean theirs no way of updating to os v5.1 unless ypu upgrade to Cyanogenmod OS
The devs of my device said they won't send out the update, but also said that I am allowed to update if I can find the OS. So if Cyanogenmod is my only option, where can I find it?
It's a DigiLand DL1010Q, which I know isn't a very well supported device. But the fact that it actually meets the requirements for 5.1 surprised me.
Yea but if no CM12.1 isnt available your stuck with the same os
Basically if you don't see your device listed here, Cyanogen hasn't got anything for it.
http://download.cyanogenmod.org/
So you're either stuck with the manufacturer ROM, or see if you can find some other custom ROM for it. Can you read Chinese? Or even try and build a custom ROM for it yourself.
Good luck!
