System sounds gone ??
AKA_Rizzo
Member
Ok mysteriously I've lost my audible touch sound.
Things I've tried.
Deselect then reselect Audible selection .
Same for touch tones.
Then an old fashion reboot.
My windows laptop just died yesterday during a SE PC Companion repair which I was doing to try to fix this, So that's out and so is flashing anything
In Astro
/system/media/audio/ui
I see all the sound files. Problem is they're not "sounding" in phone use but I can "play" them in Astro like a preview.
I have an app called Quick Settings, which breaks down the volume controls on ringer/notification/media/alarm/voice call/system volume.
Now when I look in the normal Menu>Settings>Sound & Display it doesn't give you this many options. So it might be worth a quick download to see if you can get to all the settings and see if anything is turned to zero.
