Hello guys!
this is a unlocked Nec Terrain
my phone storage (the storage available ONLY for apps) usually runs between 170-200mb, but from two days ago... yesterday i received a "low on space" message
Despite that, the only weird thing that have happened to my phone these days was a suddenly battery discharged two days ago, which i suspect was also the same moment the space went low.
i am extremely strict with the memory usage;
this is how i manage the memory
*the phone has an internal memory for apps of 787mb
*separately, has a phone storage of 4.34gb
*and a sd card of 8gb
*the memory for apps.. the phone shows it is 709mb full (78mb free)
*the phone storage, can not be used to install apps, but for anything else, for now i only use it to store maps in pdf and the map files for two maps applications, mapsme and avare, since in my daily basis i depend a lot on maps, i need them to work reliably and fast thats why i dont let those app to store their maps in the sd card neither in the internal memory for apps...
*and the sd card... you know you use it for what ever you want, i have there a "my document folder which i handle like a regular pc, and some non essential apps installed on the sd card
Now, back to the space for apps..
my total apps make about 440mb
just like always, why suddenly the space for apps went so low without any modification (from my part) to apps?
i rely a lot on this phone so i dont use to try new apps and to install any apps without doing several reviews and receive a positive information of an app, in my bag, i have another phone for playing with trend apps and new untrusted things.... EVEN UPDATES.... i first doit in the secondary phone and when i see everything working fine then usually a week or 15 days later is when i perform the update in this phone.... this is just to show you how strict i am with whats on this phone.
what is sucking my space for apps?
