OutSourceRox
Anyone got any idea of why or what might be the cause of frequent 'System UI crash'?
There are a ton of things that could contribute to this, particularly if you've modified the device in any way.
- Is your 6P stock, locked, and unrooted?
- What is your current build number? Are you on the stable 8.0 release or the 8.1 beta?
- Are you using the Substratum rootless theme engine?
- Do the crashes continue if you reboot into Safe Mode?
Rebooting into Safe Mode would help to confirm whether it's an installed app causing the issue or if there might be something else going on.
