Help System UI has stopped--Stock OS
Earlier today, I got an error upon starting up my Samsung Galaxy S5 (T-Mobile) that says "Unfortunately, System UI has stopped." My background has been turned to black and none of the buttons work properly. The phone IS rooted (and has been for about a week), but runs on stock OS (5.0 Lollipop) and stock recovery. I have never flashed a rom on this phone. I already tried restoring from a Titanium Backup I made yesterday before this error ever showed up, but it did nothing. Perhaps it's relevant that this error first happened after I booted the phone in recovery mode (to see what stock recovery looked like), then selected "reboot phone." I also already tried wiping the cache partition, wiping the System UI cache, and rebooting is Safe Mode. None of these worked. I thought unrooting the phone might help, but I accidentally uninstalled SuperSU without removing the root. With the System UI down, I can't install any apps at all, such as SuperSU again or a file explorer that would allow me to remove the "su" folder in /system/bin/. Now I have no way of unrooting, short of wiping the phone. I DO NOT want to do that. How do I get my phone back to normal?
I think if a factory reset (sorry but it's your 1st option) doesn't work, you'll have to reflash it which will wipe the phone anyway I'm afraid :(
Unless you have USB Debugging enabled in developer options and someone can guide you to using ADB (i have no experience with this, sorry) to remove root which "may" help but I'm not sure tbh.
Good luck
