Help System UI has stopped
phillyundead
Woke up and my Xperia z keeps saying it when I try to open settings. No new apps. No updates. I'm not sure what's causing it. I'm on T-Mobile and 4.1.2. Any ideas?
Here's a screenshot
Ok the system ui is the status bar and the settings . You need to do a wipe cache and wipe dalvik cache batterystats and reboot back into rom . If this don't work you will need to do a full wipe to correct the problem.
Didn't know it was a problem with cwm.but this fixed a friends phone at work . But also is stated that a hard reset through pc companion would work but this will wipe your root away . You can also wipe the settings apk clean . And reboot .
hi, im also having the same problem.
just to check if u're using a different keyboard like swype or swiftkey keyboard?
because i use swiftkey and some othe keyboard (but i stick to swiftkey). and everytime the error came up, i disable the swiftkey and power off the phone for 1 minute. then, its all okay.
it's happen on my 2 android. Ainol Numy 3g ax1 (Jelly bean 4.2.1) and Lenovo a390 (4.0.4). ---> same symptom and same troubleshoot method.
if u try follow like what i did (and if it works), then android has a problem with 3rd party keyboard apps...
p/s : before i came to this, i tried uninstalling all apps. and i narrowed down the suspect to "live wallpaper" and the 3rd party keyboard. and between this 2, i am pretty sure the 3rd party keyboard is the problem.
*** i really hope you or anyone reading this who have the same problem to verify this.
It was from me rooting and dialing a system app. I don't have the z anymore but it was fixed when I enabled the app again.
