System update changed home screen
capainron
I've owned my new Droid Pro all of two days. On day two, the system recommended I download and install a system update. After restarting, the update had made a weird change to my homescreen that I can't seem to change. I've tried a reboot, a hard reset, and I've tried dragging things around to make it look like it did before the update, but to no avail.
See attached image to see what changed. Any ideas how I can fix this?
I dont think you'd be able to change it unless the default launcher on your phone allows editing the dock. Normally that's not allowed on OEM launchers.
Agreed, this is why many people use a 3rd party launcher.
@capainron search the market for "Launcher", there are some pretty cool launchers.. you may never use the OEM launcher again :)
That is the result of the Droid Pro update to Gingerbread. Motorola changed the layout and appearance of the screen and icons too. Happened to mine. I personally like it... but as was stated it can't be changed back systematically. Third party launchers can help you though.
That is the result of the Droid Pro update to Gingerbread. Motorola changed the layout and appearance of the screen and icons too. Happened to mine. I personally like it, and without a third party launcher it can't be changed back.
It is my opinion that Motorola should have done that. Too many people become accustomed to a product and changing horses midstream is only going to anger your user base.
Thank you, everyone. I'll look in to a 3rd party launcher. I suppose I can get used to it after a while, if necessary.
The other thing this update did was kill all my contacts. When I went to try to open my contacts after the update I got the message "application not installed." It took the hard reset to get my contacts function back. Very strange.
