OK, you have a custom recovery installed. "Recovery" is a small, self-contained program that all Android phones contain, and is used for doing operations like factory reset, clearing the cache partition, or installing updates. The standard recovery will only install official updates, so people who modify their phones (rooting, custom ROMs) usually replace this with an unofficial "custom" recovery, and TWRP is the most popular of those. However, a custom recovery will not work for installing an official, over-the-air update, and it sounds like that is the problem.
That wasn't done by any official service center, so I don't know who did it: any official service centre should reflash the phone with clean firmware, so even if a previous owner had installed TWRP that should have been removed if the phone was a factory refurb. So unless you (or someone else) has done that since, there's something dodgy about whoever did the refurbing.
Anyway, if you are trying to install the official update you really want the official recovery. That can be achieved by either completely reflashing the phone (which will also wipe it, so back up first) or, if the bootloader is unlocked, by flashing an official recovery. You need to unlock the bootloader to flash recovery, so the fact that you have a custom recovery suggests it has been unlocked, but it may have been relocked. Since unlocking the bootloader will also wipe the phone you should not do that just to install a recovery.
Either way we're going to need to know more about the phone in order to find the right software. If you know how to use "fastboot" and have it installed on a computer then posting the output of "fastboot getvar all" (apart from the IMEI and phone serial number) will give us everything we need. If not, can you tell us the exact software version you are running (Settings > About, we want the detailed build number rather than just the android version) and all of the software information from the bootloader screen (bootloader/hboot version and baseband version will be helpful), and if you know what country/carrier the phone was originally sold for that will help a lot. I can't guarantee to be able to find the right software, but will try.
The other alternative is just to use TWRP to install a custom ROM. That also requires wiping the phone, but will allow you to update even if we have trouble locating the right software. The information from the top of the bootloader screen will still be helpful here.
Sorry about this mess. Nobody should pass on phones with modified software without ensuring that the recipient knows what this means and is happy with it (and I say this as someone who does modify the software of my own phones).
