I'm trying to do a system update on my evo shift and when I do a message comes up saying the sd card is mounted as read only mode and the update won't work. It is a 2 GB card. Is there any way to fix this so the system update will work?
Yeah, you might have to reformat it to FAT32
You can also try turning off your phone, taking out the sdcard, booting without it, then restarting and booting with the sdcard in again
