I specifically logged on to start a thread about this haha. Anyways, I woke up today with the update you mentioned. I've had my lil Proclaim since early June and this has been the first update I ever received. It said it was only 20mb so I downloaded. When you download your phone should turn off, turn partially the way on, show a downloading icon and bar, turn off, turn back on (which will take longer than usual) and presto.
I'm not rooting so I guess I'll wait until I can get a phone upgrade. I wonder if ST sent out this update to ALL of their hotspot enabled phones?? :O Do you know if anything else on the phone changed?It appears the new update is specifically targeted at stopping FoxFi. It has both a new modem firmware and yanks out some segments of the kernel relating to hotspotting.
No way to go back.
Only option once "upgraded" is to root your phone to install one of the other hotspot apps. So far, it doesn't seem like the ability to root your phone has been impacted.
. Oh well. I have since then rooted the phone, but I am struggling to get access to the Mobile HotSpot. I purchased the foxfi full version in Nov, 2012 and it worked flawlessly till the update. Yes, so far that is the only known issue with this update. I haven't noticed anything else besides my ability to hotspot is gone. If the ability to root the Proclaim wasn't impacted, my guess is it won't mess up the root on an already rooted Proclaim. It's just a hunch though. Oh, and welcome to Android Forums!!![]()
. Appreciate the help and welcome!
