Root [T-Mobile] adding different language
polinehk
i just bought S3 few days ago. i want to set chinese as a language input but it is not build in with it. is there anyway i can type chinese for it?
Looking at the Google apps in the play store this might work. Google pinyin ime, I think its Chinese character support for keyboards. Go to the play store and download it then go to language and input settings and keyboard settings and you should find the option to add it there. Hope that helps.
