Root [T-Mobile] cloudy G3 rom problems
Dennis7d
I installed Cloudy G3 on my T-Mobile G2. I love it, but have a few problems.
1. Gapps stopped working pops up when I turn on my phone. I tried a few solutions I found online, but nothing so far.
2. With the stock rom I could press the button on my Bluetooth and Google voice command would pop up. Now nothing happens.
3. My LTE isn't working. The settings keep changing from LTE to GSM/WCDMA.
I'm thinking of master reset, reinstall, or try a different rom.
Welcome to the forums, Dennis7d!
I'm not having any of these problems on Cloudy with my Verizon model. However, I have heard issues with LTE. I'd recommend a clean wipe and if a reinstall doesn't help, I'd look for a new ROM.
Also, moved to the root subforum. :)
Thanks, i will try that. I have 2 questions about a clean whipe. What should i whipe (delvic, chace, data). Also, i think i did the installation wrong. I read on cloudy installation form that i need to install kitkat basebed, which I did, but should that be before cloudy, then restart or after cloudy, or the same time?
You will need to Factory reset then flash the baseband then install the rom i had problems on my LS980 so i just did what i told you to do. Good Luck its a great ROM ;)
I flash the rom today
Same problem
I anstal app frome playstore
https://play.google.com/store/apps/details?id=com.tapbase.LTEswitcher
Fixed the lte
