T mobile comet
zia508
I have t mobile comet of 4 gb the apps i installed are stored mostly on phone storage i add app manager and transfer some apps on sd card it is fifty per empty but not all apps are movable so mostly phone storage gets low than i deleted some apps and add new adds how can i know what dada is stored on my phone so that i manage it
one more thing i installed quran android than i delete it but it is still in my phone i dont know where it is and i transfer some videos from my pc to phone like a titanic move but i cant find it where it is
my phone hanged again and again what can i do
Hello and welcome aboard. :)
Here's what I have to say: a larger sd card would be one way of getting rid of the low storage problem; here's an application that can help you with editing, deleting, and moving files on the sd card https://play.google.com/store/apps/details?id=com.metago.astro. You can also start a fresh by "resetting" the device to factory default settings. From there only installed applications that you used on a daily basis -- anything else is can wait until needed.
P.s. Remember to stop by your device's area of support for some cool information and tips on this device.
Hopefully you'll get things straightened out.
Thanks for joining.
Welcome!
Looks like Rush has got your covered with some help. If you have any other questions or none of his advice works get back with us :)
Thanks for joining and enjoy the site! :D:D
