T-Mobile Data Question
Optimus_User
I didn't know if this should go in the T- Mobile all roots section, or not, but here goes:
I was checking my data usage under the T-Mobile application before my first billing cycle ended, and it said 50MB/2GB of Data Used.
Then, when I checked it today, it said "unlimited." Do I have unlimited data now?
Here, look at this picture.
k179v
http://imgur.com/k179v
you have whatever data you signed up for prior to getting the phone. i also seen that i don't think that changes anything.
It looks like you were upgraded to the new unlimited 4G plan. Check your plan in the T-Mobile My Account app on your phone.
i believe thats just a program that monitors how much data you use, so if you go over your certain amount of data it would warn you. i also checked that out when i first got it, but i dont believe that can change anything on your plain
